The car just finished getting wired up and it turns over but wont start up and idle...checked fuel pump, checked ECU, and ignitor.. what else can cause this...
								Supra-Man18;1010988 said:what i did was put a ecu and ignitor from a running 1jz into my car still had the same problem... as for the coils they are fine 8 / what else can cause them not to spark ?
Syris;1012234 said:The tach moving shows the igniter is getting a signal? or the opposite?
bluemkiii;1012320 said:I'm having a similiar problem. So if the tach isn't moving at all, the ignitor is no good? or there is something wrong with the wiring?
annoyingrob;1012738 said:You should have the needle not sit at zero the whole time. It should jump a little bit, like to 200rpm or so.
If the needle doesn't move, it means either the ignitor isn't getting the fire signal, or it isn't acknowledging a fire. If the needle doesn't move, I would suggest you get some LEDs, and wire them into all 7 signals going to the ignitor. That will tell you if the signals are being sent properly
