Step 1 - Locate the diagnostic plug on your car which is in the engine bay
Step 2 - Open the plastic lid and you will see a number of connectors and a description of each on in the lid itself
Step 3 - Use a piece of wire/paper clip/something metal to short E1 with either TE1 (MS) or T (MA)
Step 4 - Insert keys and turn them to the 'ON' position - do not start the car! The engine warning lamp will now flash a sequence of error codes at you
Interpreting the codes:
If you haven't got any stored error codes the light will simply flash on then off at quarter second intervals
If you have any codes they will come out in numerical order (Smallest first). Once the codes are displayed, there will be a pause for 4.5 seconds then it will start again so don't worry if you miss them first time round
Each code will be a two digit number represented by a series of 0.5 second flashes for the numbers and a gap of 1.5 seconds between digits. Between each code is a 2.5 second pause.
An example, code 24 then 31 would be:
Two 0.5 second flashes, a 1.5 second pause, four 0.5 second flashes
Then there would be a 2.5 second pause followed by
Three 0.5 second flashes, a 1.5 second pause, 1 0.5 second flash
Then after 4.5 seconds it starts again
![p1329225_1.jpg](https://www.supramania.com/images/pb_archive/p1329225_1.jpg)
![p1329225_2.jpg](https://www.supramania.com/images/pb_archive/p1329225_2.jpg)
![p1329225_3.jpg](https://www.supramania.com/images/pb_archive/p1329225_3.jpg)
![p1329225_4.jpg](https://www.supramania.com/images/pb_archive/p1329225_4.jpg)
