It does, however, seem to be a bit slow.(the linked pictures are large ~700KB)
It actually comes with a permanent mount, which obviously can not be mounted to the windshieldFredMk3 said:Great toy! I might buy one shortly.
Haren't those gizmos designed to be installed on the windshield to give good results...? I thought so.
http://www.gtechproforums.com/forums/showthread.php?t=978
GtechSupport
Technical Support Staff
...For drag racing and road racing, the ideal mounting point would be the center of mass, which is somewhere between impractical and impossible. But for a drag race, you only have to worry about pitch (which is why you don't want to replace the hood emblem or trunk latch with a Gtech.) But with RR there is also body roll, so the center point of the windshield (L-R) is the best. I would say "lower is better" too, but not so much that the unit is vibrating against the dashboard...
Mounting it is as far as I've gottensilver88turbo said:Nice. How do you like it? And what are you running in the 1/4?![]()
isnms said:Idealsupra - what did you set the weight to? I went to the truck stop scales and they gave me a total......drum roll......3900 lb .... oink, oink, oink.
Also was it mounted very securely?
Now New Improved smaller images![]()
I got mine installed. I hope to post some pics, if it's allowed here. I mounted the base permanently in my miscellaneous bin below the radio. This system makes it easy to remove the G-Tech RR unit when not in use.
RAM mounting system for a 9/16" ball
RAM-A-101 - arm length, center to center, 1 3/4"
RAM-A-101B-arm length, center to center, 3"
http://www.ram-mount.com/ramwebcompthumb/Page0007.html
This place was the least expensive I found but they say 4-6 weeks delivery and they mean it. I got mine right at 4weeks.
http://store.getagps.com/rammoac.html
RAM DBL. BALL MOUNT W/ 9/16" BALLS - RAM-A-101 = $19.26
UNPK RAM SYSTEM W/ 9/16" BALLS LONG ARM - RAM-A-101U-B = $25.77
