Group A's group a rebuild
Just trying to work out of it's Bill or Ben ;)
Or maybe a Member of Devo!
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
group a supra said:
yannis glad you like it ;)
i will need to take some photos for you but to be fair they are the same as the top :)
Hmm...I guess it has to do with the structural differences between the mkiii and mkii then. You see my intercooler is in no way bigger than yours :aigo: but it's still quite big, here's a clue:
so basically the top is level with the top of the bumber where I mounted two brackets but the rear is way off the lower frame support, plus I have the oil cooler hanging right behind the lower portion of the intercooler. So two straight brackets similar to the top ones are out of the question :(
P.S. Werd on the alt issue; I got a reconditioned Cressida unit (oem Denso) from the states, upgraded to 155Amps which is infact smaller in size than the mkiii unit (hint hint for relocating). I bench tested it when I received it about a month ago and it easily produced 125Amp numbers. The cost inc. shipping to greece was about $200 plus it's got 1 year warranty.
group a supra
SPAWNING AN INTERCEPTOR
YANNIS thats good to know but dont forget mine is already relocated (alternator that is with a ron r bracket ;) )
ah as far as the intercooler goes i'll post some pics for you as i sort ripped everthing out on mine to make room for it ;)
group a supra
Allan_MA70 said:
most diesels have a vac pump on the back of the alt' you maybe able to ditch the vac pump and mount a PS pump to the ass of it!
allan that is like real good to know so now all we need to find out is which manufacturer uses a denso alt the same size as the sup on a diesel with this system
answers on a postcard to -----------------
lmao
no seriously allan if the above is poss it would solve the whole problem :)
group a supra
nothing done but research today have ordered another 2 4" alloy 90 degree bends to cope with alterations on the intercooler pipe work and have gone with a 48mm turbosmart pro gate wastegate which will be winging its way over from australia via turbo charged turtles i hope so i can get fabbing next week :)
group a supra
Today
got home from work and look what i found :)
one rather large 48 mm progate from turbosmart and i have to say the quality is exceptional as i would expect from the homeland of ian and motec ;)
need to go see my stainless supplier tommorrow for some 50mm 2.5mm wall stainless tube so i can rig her up :)
