Group A's group a rebuild
group a supra
SPAWNING AN INTERCEPTOR
. How will you make the runners come off the main block flange though. My runners are already bigger that the block's ports. Will you use reducers, like let's say 38mm short runner widened to 48mm and take it from there?[/quote]
the runners will come of the head in 48mm ;) thats how you get the tq ;) it stops it flowing back into the head and stalling the flow of gases acts like anti blowback system as the gases will always go to the outside wall :)
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
So if I get this straight, the ports on your main flange are of equal diameter to the engine exhaust ports, right? And you weld the wider runners straight to the flange, so if for instance you can look inside the runner towards the flange you can actually see a step to the motor port? Am I making any sense here?
group a supra
So if I get this straight, the ports on your main flange are of equal diameter to the engine exhaust ports, right?that is correct ;) And you weld the wider runners straight to the flange, so if for instance you can look inside the runner towards the flange you can actually see a step to the motor port? Am I making any sense here yes you are spot on sir :) you got it one ;)
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
I'll definatelly ask him tomorrow, this is too good to just pass like that. (Homer voice) MOOORE TORQUE :yum:
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
group a supra said:
lmao let me know what his face looks like when you tell him or just take a photo :biglaugh:
I can be very persuassive when it's needed, in a good way I mean of course. I'd pay something extra if it will actually make a difference. I don't know the diameter availability but I think I could go for 45mm. 48mm will cramp everything in there, there's no way the runners would be able to bend in a similar way they are now.
group a supra
45 sounds good about same size as the ss manifolds what wall diameter though i have gone 2.7mm wall after a lengthy chat with ian that includes the collectors as well
IHI-RHC7
"The Boss"
Oregon
I think you should just pressure seal the engine bay and mount the 42 on the hood. That way the only way for the exhaust to get out of the bay is through the turbine. You'd get lot'sa low end torque that way...
group a supra
jake you have bought a smile to my face roflmao here with the odd tear as well :biglaugh:
your comment has just topped of what has been national wtf day here in the uk has anyone else had national wtf day as i suspect it could be international wtf day lol:naughty:
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
Ok, I had a good talk with my exhaust guy yesterday and after I told him about the benefits of a larger diameter runner he objected with that aproach and insisted that a smaller runner would certainly benefit the torque band whereas a wider runner would require more air from a bigger motor.
Ian agreed on this as well as my setup is totally different to yours.
So I'm sticking with the 42mm runners, which as I said before, I thought they are quite big as they are.
group a supra
TODAY PART 1
spent a fair few hours moving the turbo again :(
but looks like i now have it in a position that i can work with on the runners as i wasnt happy with them
i might add it is about 9" further forward now :)
group a supra
TODAY PART 2
thought better get stuck in to the manifold so here we go another 5hrs later 2 runners complete and it is already heavier than a standard manifold
IHI-RHC7
"The Boss"
Oregon
VERY nice Steve!!!
Your CPS will melt though... :(
That's looking more and more like the RPS mani...
