Could be spark blowout and when the silencer is in it cuts down on the flow through the motor which in turn lower cylinder pressures which prevents the spark going out which makes it drive better
IJ. said:Could be spark blowout and when the silencer is in it cuts down on the flow through the motor which in turn lower cylinder pressures which prevents the spark going out which makes it drive better![]()
bobiseverywhere said:rakkasan
i just thought of something, I sold you that Tech Tom Rom board right. Is it possible a setting you have on it is the cause of your issue if you have it installed. Or have you not put it in yet?
Ric said:Easy way to tell if you have bad grounds....
Hit the brakes or turn the turn signals on. Do your dash lights go dim? If so.. bad ground.
Ric said:To me, sounds like you have cracked coils. Everyone does lol just some are worse then others
rakkasan said:BLAH, BLAH, BLAH.... Could the car run so rich that it causes the problem?
