Gotta love that fuel hard line at the gas tank
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
Damn thing kinks so easily.
Went to prime the new turbo with oil after having just installed my Walbro while having it jumped from my truck to keep the battery from going dead from cranking it. Put the EFI fuse back in, no start :cry: Check under the car and hurray gas on the ground! At least I know I wired and installed the pump correctly, there was a lot of gas from just simply cranking it :3d_frown:
Time to either drop it again. Either going to cut the hard line straight before the kink and a little bit further and get a rubber fuel hose from Delta rubber, or spend the $80 to get an entire new assembly from Toyota... Woooooo. :icon_roll
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
im in the same situation as you are except i didnt put the tank back up yet i kinked it while trying to loosen it.....im most likely going to cut it before the kink and give the rubber fuel hose a shot.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Or, you could put in a braided stainless hose. This cost less than $45 bucks.
(it is a -6 to 1/4 npt elbow threaded into the a hole drilled where the hardline used to pass through. I bored the NPT end of the fitting and brazed the old hard line into the elbow.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
I was thinking about that. Did you weld a bung or whatever on the assembly side? Does the other end go into the stock fuel filter rubber line?
EDIT: Wow I just completely overlooked the second line of text in your post... haha. My mind is on the stupid black widows that made a habit of nesting in my rear passenger wheel well..
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i would think of saftey and effort in doing it again cause the shit hose you used failed 2 years latter..
worst case it fails on the next owner in his driveway and not while he's driving..
i do like how you did the braided set up.
im doing the same thing but i didn't crimp the old line so im having a facotory line made in ss braided flex line..
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well it very easy to take off just took one off a car the other day it called lube it frist and use 2 wrenches
and when install use anit size never an issue again how simple is that
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
i had similiar problem once, i just got some fuel injecion hose and put two clamps on each side of it. i needed the car to be running right then though, if you have the time go for a better fix.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Same happened to me, I put rubber fuel hose on and pushed it about 6 - 8" up the pipe and then put 3 clips about 2" appart to make sure it doesn't leak. The rubber fuel hose I used is rated to 8 bar so the pump will run out of capacity befor the pipe bursts.
casgallo
Not a lurker :)
Apr 3, 2005
68
New York
LOL if you think that shit is going to work in some place like here in central NY.
If one of you is going to use rubber hose they do sell a HIGH pressure rubber hose for fuel and I would recommend using it. I have seen that low pressure hose dry out and crack after just a few years but the high pressure has been A-OK for many. hope this may help some.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
I ended up buying a high pressure rubber line. Put two clamps on each side as an extra safety measure. Just came back from the gas station. That Walbro whine is relatively loud.
Sawbladz
1,727
Oshawa, ON, CA
I dread the Walbro whine. Mine goes in in the spring and I hope it doesn't piss me off too much.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Rubber high pressure fuel line will be fine if that's the way you want to fix it.
In the purist sense it's not ideal but in practicality it will work out fine. It will not burst from pressure or harden in a year (assuming you use good quality high pressure hose).
As far as walbro fuel pumps go, yeah they deliver the fuel but are very loud for everyday use. I had one and took it out because of the noise.
I now use the stock pump with an external electric pump that I switch on only at the strip. No fuel starvation or delivery issues whatsoever.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
Yeah, the noise doesn't bug me to that extent, haha.
I test drove it some more last night for about 25 minutes. Twenty of those minutes were spent being scared to punch it. I am going into unknown power territory with this 57 trim.
Of course after I punched it, I blew the 90 degree hose behind the head.
