god damn code 21 25 26 34
LamaRossa
One and Only LamaRossa
Apr 6, 2005
131
ct
is this possible
driving home the other day i saw the check engine light came on
got home i reset the computer and it went away
came on again tonight
while driving home
normal
runs great
idles fine
just the codes
21
25
26
and 34
anyone got the code list??????????????????????
please post
thanx
lamarossa
88YotaTurbo
658
Wolcott, Ct.
Hi Lam I see you arround the pike alot. I just ran through my manual and came up with these.
21 - Oxygen sensor signal
25 - Air-ratio Lean malfunction
26 - Air-ratio Rich malfunction
34 - Turbo Pressure (AKA sometimes fuel cut)
shaeff
Kurt is FTMFW x2!!!!
11
Around
sounds like a boooost leak! and damn, i gotta fix that link in my sig. :(
-shaeff
IHI-RHC7
"The Boss"
Oregon
Lama, it is probably a boost leak or a bad o2 sensor combined with hitting FCO at some point in time since you last reset the tccs. Pull your EFI fuse and go for a drive, then report back.
Diggin the lights ;)
LamaRossa
Apr 6, 2005
131
ct
thanx again for all the help gentleman
im gonna buy a new o2 sensor keep swapping old ones for sometime now
weird that code for boost signal
because i never boosted on the way home to the point where it have hit fuel cut so i dont know will lookinto boost leak god damn it
im sick of fixxing shit
thanx again guys
i will report back
lamarossa
LamaRossa
Apr 6, 2005
131
ct
ok report
just went out to my car
i did not do anything to it
check codes same shit 21 25 26 and 34
then i reset ecu fuse
all code gone
then started it up fine no codes i did rev it a few time no drive
everything seem ok
shut it off
read codes again everything is ok
i test the o2 sensor on the car while running
signal voltage = 400 mV within seconds then jump to 973mV
shut it off
i got 250 - 350 mv so my o2 sensor is ok
like i said ran fine home, drive fine ,idles fine just check engine light last night
i'll drive it soon and see it it throws codes again
what the fuck supras
my 87 na has absolutely no prob fucking turbos
lamarossa
