1st of all Poodles is right 77k miles doesnt mean anything, rubber rots and hardens over time(which means a blown coolant line and then warped head)
i bought my 91 with 76k miles and garage kept. i replaced all common maintenance items before the jump into more power(fluids, belts, spark plugs, wires, hoses, brakes, brake lines, filters...etc)
once i new my car was running well enough to handle power i then started to modify
start with upgraded air filter, 3 in down pipe, 3in cat back exhaust, install a ELECTRIC boost controller(MBC tend to change psi with weather change), set boost to 10-12psi
if your not happy with that then proceed with more upgrades like a 57 trim ct
at 1 point you will need to address fuel cut and needing more fuel
youll need a way to pump more fuel into the engine...so higher flowing fuel pump(walbro 255 does nice), bigger injectors(common 550cc), adjustable fuel pressure regulator(driftmotion sells a kit)
with that said youll now need a way to control it and make fuel cut stop bitching...this is where you decided wether you want to go with a lexus afm/safc combo or other tuners(piggybacks)
maft pro, emanage, apexi safc, hks vpc, standalone....really it endless
research...theres this real nice feature on this forum
scroll up and theres a search button...use it and youll find what you need or use google
