Getting code 11 what do I Check?
Tysree
33
Gresham OR
The main relay seems to be working as the car still starts and idles.
Could this mean my ecu is toast?
Codes 31 and 51 went away?
Im very confused...
Now it's just the 51 and not the 11 any more...
radiod
1,342
Abbotsford, BC
I'd echo what Grim said. They are just ring connectors that bolt on where your lower and upper intake manifold join. Make sure they're clean and they have a clean surface to make a good connection.
Oct 11, 2005
3,822
26
Thousand Oaks, CA
Check for damaged insulation allowing the engine wiring to touch metal engine parts as well, especially the O2 sensor wire and the loom where it goes past the EGR valve.
