Gas door cable fix?
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
My gas door wont open when I pull the lever. It seems as if the cable has stretched. Has anyone replaced it or fixed it somehow? If so, any tips or helpful hints?
BrandonW
1,300
N.J.
when my car was getting painted i asked them to fix mine so i bought the cable the spring and that little black piece that helps the door part open
it should be the spring part that you need to replace
BrandonW
1,300
N.J.
i keep all my part receipts
it should be this part 77037
my supra is a 89 though so im not exactly sure if thats part number is the same
staticpage
Banned: Scammer, liar, cheat and thief
Oct 3, 2007
310
Cincinnati
Doing that right now
To get to it I had to remove the back pass panel. but to do that you have to remove every panel behind the pass seat all the way to the back. I was doing other things in that corner so no big problem for me. but it was a 1hr ordeal of removing this to remove that. used the tsrm and did not brake a clip.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I just replaced mine as well. I ended up prying my door open (no paint and a broken door hinge). I bought a door and new latch in the For sale section here. I was able to swap my latch out without removing anything but the access panel. It took about an hour, mostly because getting the cable routed was difficult without seeing it. I had the old latch to go by, and I let that guide me.
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
I replaced my cable and it still wouldnt open. So I took a shorter cable that went from the hatch key hole to the hatch latch. I ran it so that you pull open the acces panel and open it from there.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Mine wouldnt open one day, my cable actually came unhooked from the clip on the latch. I had to remove the whole panel to put it back together but all in all it only took an hour or so. Its worked like a charm ever since, so if the pull has gotten any lighter since it quit working you could check that.
shaeff
Kurt is FTMFW x2!!!!
11
Around
No prying necessary. With relatively thin arms, you can reach up through the access hole and pop the gas door open via the latch on the inside. :)
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
mine froze up over the winter, and i have been doing what shaeff said for the last few months for every fillup.
unfortunately i dont have very thin arms haha.
come warm weather, ill get her fixed
