game over.
Tanya
1,851
Naples, FL
Tanya
1,851
Naples, FL
yeah. my life hates me. we're so fucked now
no warning at all. oil level was full, pressure was good. BAM
I wonder if there's a hole in the other side too, because somehow it managed to take out my clutch slave cylinder which is on the drivers side, wtf
Tanya
1,851
Naples, FL
No this was owners error, this wasn't the 5MGE just crapping out cause it felt like it.
You have to remember I had a BHG for quite some time, and even though we tried to keep the oil fresh, it still had a lot of water sloshing around. This was a brand new crankshaft btw, was installed early this year. The water killed this engine I would imagine. Will look at her more in depth tomorrow.
I will not go 7M, 1J or any other engine besides a 5M, not unless someone will give it to me free and it's ready to be installed immediately.
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
Im so sorry Tanya!!! You are right going any other engine that what you have is just a waste of time and money if you need the car. Good luck!!!
Tanya
1,851
Naples, FL
ok daylight = can see more now.
i found a chunk of block sitting on part of the frame near the shock tower. apparently the freeze plug on the drivers side was blown clear out, the starter is destroyed, ripped right off the bellhousing. the oil pan is slashed like a dotted line.
will have more pix of 5M carnage in a bit
Tanya
1,851
Naples, FL
More pix:
Took out the bottom of the block too
The other side
block chunks
oil pan
slave cylinder
supra90turbo
shaeff is FTMFW!
32
MA, 01440
such carnage. I must say, excellent work Tanya.
Although it sucks that the car is now dead... :(
I hope you a speedy recovery
Tanya
1,851
Naples, FL
Kai said:
Yargh - that's done some serious damage :(
However, its just the block thats had it, right?
The block, the oil pan and the starter = wasted. Dont know about the tranny yet, no visible holes in the bellhousing, the car drove fine up until the clutch pedal fell out due to the slave cylinder being knocked off. Hopefully the clutch, PP and input shaft are still good. I'm going to assume the flywheel is toast.
figgie
Twin Cities, Minnesot-ah
Hmm
looking at where the rod gave way... just seems fatigue failure as it seems right smack dab in the middle of the rod. The crank still looks fine. The block on the other hand..... :/
Tanya
1,851
Naples, FL
what really pisses me off is that I was building a good dyno history with this engine. 132whp stock, 144whp with exhaust. I never got the chance to dyno it with the intake. I'm sure she was putting down at least 150, but I'll never know. And any other 5M is going to put down different numbers.
RAWRRRRRRR
