fun times qestions
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
for fun here peeps
if you had persure gauge monted were you waste gate is and one at intake manfold and inter coller between them
whould they be the same and if not why not
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
Are you talking about a pressure gauge on the waste gate signal feed line directly from the turbo compressor? If anything, the pressure would be less at the manifold than at the turbo compressor. Air loses pressure when it is cooled down. I doubt it's very much of a loss though.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Pressure at the turbo is considerably higher than at the manifold. One of the local guys was running his GTE in a pickup truck without the IC - pushing from the turbo straight into the intake. I seem to recall he was getting about 13 psi where we normally get 7.
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
It depends on the efficiency of your setup. Plumbing design, intercooler, manifold design, ect. But there will ALWAYS be pressure loss to some degree.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
now was that from the lack of volume or more of just the cool down
i was told that cfm is more importaint then just the cooling afect that is gives off cause the trubo will still regulate the persure
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
It is pressure loss from moving the air from point A to point B through the bends of the tubing/intercooler. You can calculate a rough estimate of what the pressure loss is for your setup through the tubing and then add the pressure loss of the IC if you can get data from the IC manufacturer.
