Fuel Warning Light
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
TaSe said:
i wondered this myself.... i've never driven the car untill the light when on. I might actually do that some time and see how far i can drive b4 the car runs out of gas.
I wouldn't if I were you, since the answer of 2-3 gallons should be adequate enough. Mostly because you don't want any of the particles of whatever is in at the bottom of the tank to get shot through your injectors.
theprodigy79
Irish Cream
Mar 5, 2007
221
Centreville, VA
Sorry to be a bit off-topic, but how bright are your fuel lights? I can HARDLY see mine when it comes on if there's any sort of glare! I usually wait 'till it comes on and has been on for a bit before I get gas, so it's really annoying in day light when I have to cup my hand over it to see if it's lit (and sometimes still can't tell)... At night it's usually fine though!
PS--> I usually drive 20-30 "easy" miles after the light comes on (I milk it, I don't rev or accelerate hard).
p5150
ASE and FAA A&P Certified
Central Idaho
Justin - fill up your tank when it comes on and let us know how much it takes. The tank holds 18 gallons right?
1988SupraDreams
509
San Jose, CA
It comes on at 3 gallons, but goes on and off after that because gasoline sloshes, I tested it with the gas pump as well, but it also says it in the OWNERS MANUAL! haha
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
My 91 sort of fades in and out when the gauge reads about 1/8 of a tank. I just ignore the light, and fill up when my car has trouble starting, which is when there's about 2.5 gallons left.
it also says in the owners manual to not drive it around with the light on, but to get fuel immediately or engine damage could occur...
yes it's dim, and yes I drive around on it. it comes on at around 3 gallons left...
Z'mnypit
116
Springville, AL
Im trying to run out most of all the old gas thats in my tank so Ill test it and see how far I can go normal driving before it runs out. Going to make sure I fill up the gas jug the day the light comes on. LOL.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
It gets brighter the lower the fuel gets.
