Fuel Pump ?
Emik87t
GameOver
May 30, 2007
213
Iowa
Okay i have a walbro 255 in tank, and 550cc injectors, now im upgrading to 880s and another walbro, will i need to put it in the tank as well, or does it run in line? What's the best way to do this?
shaeff
Kurt is FTMFW x2!!!!
11
Around
Emik- you need to change your sig. it's offensive, and will likely cause problems if people try to log into SM from work.
thanks,
-shaeff
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
looks something like this:
I'm just about to do this myself for my 1JZ.
Emik87t
GameOver
May 30, 2007
213
Iowa
where'd you get your bracket? And about how long did it take for you to hook them up? And did u leave your stock fuel line/hose?
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
annoyingrob did you run a better/extra power feed to the rear?
annoyingrob
Boosted member
Jul 5, 2006
2,304
That's not my setup. I just took the picture from the internet. But you do need to run more power. Run something like a 10ga wire to the tank, put a 30A relay there, and activate it off the stock line running to the tank. As for hose the setup I pictured was for a WRX, and they did use the stock hose. The bracket is the stock bracket that held the OEM fuel pump in the tank.
gixxer750: if that comment was targeted at me, then yes, my 800cc injectors are already controlled with a standalone (v-pro)
