Hey im toying with the idea of getting a bigger fuel pump as Id say im well on the limits of mine and getting temped to see what its like with a little more boost..
I currently have 1 single 255lph walbro and 680cc inectors and have been tuned to 515rwhp @17psi
for simply ease of instalation ect I would like to stay with just a single pump also I drive my car on the road and it smells bad as it is I do not want a external/surge set up in the car
pumps I have had my eye on are
Aeromotive 340 LPH Intank Fuel Pump
Walbro 400 lph InTank Fuel Pump 800+HP NEW PRODUCT
Deatschwerks 320 LPH
Denso Japan intank 305ltr fuel pump
the denso is the most expensive the others are within $20-30nzd of each other
The walbro just on lph seems the pick of the bunch are these able to support 600+rwhp like they claim? I do have a bit of faith in them as my 500hp pump net me more than that to the wheels
These pumps flow an amazing 340LPH at 40 psi & 13.5 Volts.
At 90 PSI, they still flow a MASSIVE 200 LPH!!
If you have a serious Horsepower car that needs a BIG intank pump, then this is the pump for you!! And the Best part is, its the same physical size as a Walbro pump! No need to fit the Bigger Bosch 044 intank anymore, This is the only pump you will ever need!!
This brand new, GENUINE WALBRO 400LPH High Pressure in-tank fuel pump can support over 800hp (at the crank) when supplied with 13.5V!
The DW Advantage
•Flows 320 litres per hour ( A Walbro only flows 255 LPH)
• In-tank application specific fitment
• Ethanol compatible
• 3-year no-fault warranty
• Quiet and reliable turbine impeller
40psi 390lph 9.5amps 14v
50psi 350lph 10.5amps 14v
60psi 305lph 11.5amps 14v
70psi 258lph 12.5amps 14v
