Fuel options...
yask4it
7m nut!!!
Oct 14, 2006
23
north carolina
ok here is the deal... I am working on getting everything together for my n/a-t setup.... I am goin to be using the n/a electronics..... So I know I am goin to need to use some kind of piggy back ecu setup to control fuel and what not.... I am goin to be using the MSD BTM setup for the timing... I have been looking into running the map ecu setup so I can get rid of the MAF..... I have also thought about just using a safc for the fuel control.... What would be the best option to go with runnin the stock turbo setup with aftermarket intercooler and 3 inch down pipe on n/a electronics.....
Doward
4,245
Alachua, FL
You could go with a rising rate FMU (would need a Walbro fuel pump) - but I really dislike them.
Rather than the MAP ecu, I'd go MAFT-Pro.
Run a MAFT-Pro, stock turbo 440s, walbro fuel pump, set your timing 2-4 degrees under stock, and run 6psi all day long.
If you already have the BTM, use it - if not, then don't bother buying it. The money you would spend on it, you could get the stock turbo electronics.
What are your long term goals?
tissimo
Stock is boring :(
Melbourne, FL
I would consider a maftpro then if you budget can support it.. Retard timing in boost as needed... no need for a msd btm (which needs an msd ignition box i think)
yask4it
7m nut!!!
Oct 14, 2006
23
north carolina
I am just lookin to run around 6-7 lbs... The reson I was lookin into the map ecu is because I can get one for 250 bucks.... I would love to go with the maft-pro but my budget casn't really swing 500 to 600 bucks.... I was goin to run the msd btm so I could retard the timing for boost inside the car... I will be dyno tuning it when I am done....
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
I'm going to be doing what you are doing, and turbo electronics would def. be easier for you..
Doward
4,245
Alachua, FL
It's $399 for the MAFT-Pro ;) It does sooo much more than the MAP ECU, as well. DEFINITELY worth the price difference!
If all you want is 6psi on the cheap, I'd just toss a walbro 255 + rising rate FMU in there.
But trust me, once you get bit by the turbo bug, you WILL want more - just do it right the first time!
