fuel gauge not reading
gloops
26
richmond
My f/g either doesn't read at all or is intermittant. I can live with it if this would be a major fix presumably involving the fuel tank.
Any sage advice would be welcome.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Yep, what Ian said. There used to be a writeup on how to clean the contacts, but it's fairly straightforward.
It does require dropping the tank, and if it were me, since I did all the work to drop it, I'd rather have a new sender.
Usually all it takes is to clean the contacts where the level sensor slides, however.
shaeff
Kurt is FTMFW x2!!!!
11
Around
TweeT91109;1524827 said:
cant u access the pump, from the panel next to the spare tire? I guess this is just a neew question, cause idk.
No, to access the fuel pump, you need to drop the tank. The access panel you see near the spare tire well is for the fuel level sender, as JJ linked to.
gaboonviper85
3,236
Northeast Philly
No...you must drop the tank to get at the pump:-(
either way it's not a very big job...maybe 30min job for someone who's done it before.
