Fuel damperner
gofastgeorge
944
Texas
You should make this a 'No', even if you have a 'Yes'.
They are very susceptable (esecially how old the cars are now) to failing, and spraying the engine bay down with fuel.
Sorry, but I do not like 'Southern Fried Supra'..........
AJ'S 88NA
2,419
Florida
Ways to get rid of it, or is it needed?
isnms
United States of America
Oklahoma
i80.photobucket.com
quote from Justin's sale thread:
Justin;1380216 said:
The bolt that is in place of the fuel pulsation dampener on NA's. If you want to get rid of the FPD then you can do so with this bolt.
edit: Oh, but it does provide a function. Kind of a shock damper for your injectors. I'll see if I can find the technical info later...
EFI #3 - Fuel Delivery & Injection Control said:
Pulsation Damper
Although fuel pressure is maintained at a constand value by the pressure regulator, the pulsing of the injectors causes minor fluctuations in the rail pressure. The pulsation damper acts as an accumulator to smooth out these pulsations, ensuring accurate fuel metering.
