Fuel Cut?
Neil W
Fall River, NS
Hello! I bought an 87 a few weeks ago, and have been driving it for about a week. Tonight, halfway through a drive, on the highway, the car stumbled going up a hill. It was like I turned the key off, paused and turned it back on. After that whenever I tried to accelerate, even "normally" or gently, the same would happen. if I left the throttle part way down, it would cut in and out until I let off the throttle. The car is still driveable, but only barely.
I have done some reading on this, and I understand that there is a fuel cut, that may or may not also cut the ignition.
From what I know about NA cars, this sounds like a dirty fuel filter.
Any insight would be great...
The car is completely stock, 141000 kms.
Sounds like a boost leak...one of your IC pipes split or came loose at the connector.
Neil W
Fall River, NS
Alright, I'll fifth it. heh heh
Thanks folks, I'll report back.
I guess if there is an air leak after the MAS, the car will have the wrong info for mixture.
If I unplug my MAS, will the car use the O2 sensor? That would be an easy way to confirm... not that looking at the IC hoses is hard. :)
Neil
The 7M doesn't have a MAS, it's an AFM...unplugging it will do the same thing, just worse ;)
It doesn't use the O2 sensor that way.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
Dont you have an NA? If so, then you posted in the wrong section and you shouldnt have a problem with a boost leak. You might have unmetered air getting past the AFM.
If you are a turbo, then i will agree with the boost leak
-pete
Orangeracer
SUPRA LOVER
Sep 12, 2008
82
Harford County, MD
i bought my car and it had that problem. needed a fuel filter. although i replaced the new pump anyway. lol if i were you i would drop a walbro in and a new fuel filter. its a pita.
Neil W
Fall River, NS
Thanks for the help. It turns out that when I replaced the exhaust manifold gasket, and repaired all the stripped threads, I did not tighten the hose clamp on the outlet side of the turbo. It's tight now, and the car boosts to ~5-6 psi. Under full throttle on the highway it seems to hesitate a little. Not quite stumble, but the power is not smooth.
From the difference with that hose clamp, I am thinging I am looking for a smaller leak in the induction side, after the turbo. Not too worried, as a litte rich won't hurt.
Or maybe the plugs are all fouled from the week of driving around rich!
