Front Suspension.
customs
175
Edmonton Ab
Hey guys,
I was pulling the wheels off my supra the other day to install my new megan track coils and found that the front upper ball joints were pretty loose.
What should I do about this?
Replace the whole control arm with an upgraded control arm or just the ball joint? I have looked into JIC control arms, but they are a little pricey. I also havent had any luck finding upper ball joints.(have not checked with dealership.)
please recommend any part that you think about work best for my situation.
Thanks in advance for any useful responce. :icon_bigg
customs
175
Edmonton Ab
Moy;1478967 said:
You can't replace the upper ball joint without replacing the whole control arm.
I figured as much.
What is a good upgrade for the upper control arms then? Is there another option other then JIC?
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
it is pretty rare for the upper joints to loosen up unless there is some serious play in the lowers for a significant amount of time. Unless you need the camber adjustment that the JIC arms offer, go with stock. Good luck finding the jic arms as well.
