Front nose cone removal
swaq
posts++;
May 24, 2005
1,351
Oregon -> Arizona
www.SwaqValley.com
I'm having trouble getting the nose piece (in front of the hood) off. I believe I need to take it off so that I can reattach an emblem (please correct me if I'm wrong here). I couldn't find anything on this in the TSRM.
It seems to be stuck where it attached to the fender. I took off two 10mm bolts on the left side under the left headlight but it still won't budge. When I look through the frame a bit I can see another bolt on the inside just above where the trim attaches, and I'm almost positive that it is what's holding the piece on at that corner. How can I get at that bolt? Am I going to have to take off the whole front bumper?
Pics for reference:
Need to put this:
Here:
And I'm stuck here (circled where I took out the two bolts):
Picture of area from behind partially disassembled headlight (arrow is pointing to where the bolt is I think I need to get to):
Picture from under the headlight toward left fender (circle and arrow have same meanings as above):
See the pic with the circle?
They're inside there I use a 1/4 drive socket with a long extension from inside the fender with the plastic inner removed.
Helps if the wheels are off!
mkIIIman089
Ohio
Just some screws inside the wheel well, and 1 or 2 bolts underneith the car just in front. You'll see them, its easy.
