front mount intercooler
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
what companys have good front mounts? im looking at the maxx auto works and horsepower freaks, wht others are there that are good, is the horsepower freaks one good, post pics of your front mount also
socc924
CT and Philly
I got a megan racing intercooler. Havent even run the car with it yet but heres a pic of it installed.
oneandgone
40R 6 SPD SC3
A lot of people have trouble with the service they receive from Maxx Auto, however it's unanimous that HPF rocks! I'd go with theirs over the Maxx.
I'm running a Hybrid "monster" i/c...it looks to be the same i/c as the Megan ones that sell for $2-300 to me. Here's a quick pic...
Ckanderson
2,644
The beach
OOOOOOOOOOOOOORRRRRRRRRRR
cartech and AMS (one in the same) make stock drop in.. and they are DAMN good
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
sp m7 can you post some pics of your front mount on your car, and hottscennessey what kind of custom work was involed in putting the maxx ic on?
SP 7M
Use your GUY instinct
Apr 6, 2005
274
Oceanside (for now), CA
Sorry man. I'd be happy to give you pics, but as the sig says, my Supra and I aren't living together right now. *tear*
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Here are some really old pics of mine. I'm using the stock bumper and I wanted to keep the bumper support in place, so i had to cut it with a circular saw and a metal blade. That was about the worst part of the custom work, I had to relocate the oil cooler as well. There is no issue other than that, but i knew i'd have to work with it, considering its not supposed to fit behind the stock bumper. Radiator overflow fit nicely, i had to cut out some of the support for the horns. I got mine used for about $700 and i'm very happy with it.
If they dont show up.. Intercooler
supra90turbo
shaeff is FTMFW!
MA, 01440
yikes...
um... NO point in installing that ic...
you are now effectively using 10% of it, and the rest of it that is blocked, is actually re-heating the air that gets cooled, so that ic is practically useless...
vent the bumper and support at least.
btw... anyone interested in buying a maxx ic kit used?
price is same as what hottscennessey paid. $700
Adjuster
Has anyone tried a "bottem breather" setup for the FMIC?
Basicly I want to copy what has been done with Vettes/F bodies for years. They locate the grille opening under the front bumper, and then use a shroud to draw air up over the radiator.
It works as long as the air can't go anywhere else. (Good shrouds are everything here.)
We don't need much of a shroud either. Just cut the lower part of the bumper, angle it up to the top of the FMIC, and it should pull air over the core all the time. (Even though the "grille opening is smaller than the core, it's going to flow the air through it.)
This type of setup actually works better as you go faster. (High to low pressure diferential, and the air always goes from high to low.)
Vents in the hood would make this work better. (Draws more through the radiator, and that means more through the FMIC as well.)
I have not seen this on a Supra yet. (And our cars are setup perfectly for it.)
drunk_medic
7Ms are for Cressidas
Woodstock, GA
I wanted to toy with this later on. I wanted to make a "scoop" that would be made from sheet metal, locate it under the intercooler and make it direct air up to the radiator instead. Same thing, just a different heat exchanger.
group a supra
SPAWNING AN INTERCEPTOR
supra90turbo said:
yikes...
venting the bumper will help but as long as 35% of it is showing air it will nearly as effective as 90% showing and that came from a group a engineer
supratkfy
San Francisco
pic of the mounting process.....its an ebay core bar and plate, similiar to that of the Megan....could have went with a bigger one but i'm happy with that since i'm not aiming for HIGH hp...
i need to get pics of my car with the bumper on...also i cut the grill in the front off so it shows off the IC...i only did it since my bumper was cracket and the grill was half off already....
