what is it for??
i figure maybe to keep dirt out of the engine bay?
might replace it, wanna remove it all together. any thoughts??
mine is cracked and all bowed out.
Looks, and so you don't scrape the fuck out of your real bumper...I think thats about it. Most people don't have one, or they just get an after market one. Trying to find a lip that isn't fucked all to hell is pretty hard.
Also, if your lip is warped is more than likely because the bar it mount to is warped to hell. Gotta remove it and straighten it (not easy to get it perfectly straight). Then the lip needs to be unwarped (careful use of a heatgun works).
It helps to lower drag by limiting air underneath the car and by deflecting air around the tires.
It doesn't really do all that much but it's definitely better to have one than to have a big gap from your bumper to the ground, which will introduce more drag from the front tires.
I found a write up that Facime did when I had my last Supra. He made his own front lip out of a few home depot materials. It turned out pretty good. Just search Bumper Home Depot Fix.
