So it looks like i found what the squeak was from the lower part of my engine. Not rod knock (yes IJ.. lesson learned lol) but looks like the head of a bolt that was sheared from somewhere or place unknown..... was loose in the timing cover and ate/spun loose a metal ring behind the crank gear. You can see in the pic below. I placed the bolt up top the crank surface.
The teeth are fine and the shaft isn't scored to bad at all because I only drove a mile after this happened.
Anyways my question is... what is this part my finger is on that got damaged and what sort of job is ahead of me?
