Frame Strength
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
I have an 87 N/A. I am upgrading to a turbo engine soon and will be making over 450 hp with the mods I plan to do. Do i need to strengthen the frame at all? Or will it be able to handle it.
JonoTurbo
Going for broke
CT
The only frame failure i've ever seen on a mk3 was the rear subframe cracking.(Probably due to hard launches) Later supras (from 89 up or something) had reinforced rear subframes.
Other than that mk3's are built like tanks.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I've seen a Corolla twisted from too much torque to the point that you can only get three tires to touch the ground.
The only way I've seen a Supra do the same thing is after a severe accident. :)
There's no difference between the NA and Turbo chassis that I am aware of.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i slightly twisted the frame on my firehawk, back when i had it, my friend kris runs his car constantley and hes only had problems with the rear subframe on his car, and thats even after running the hell out of it at the track with MT ET drags
