found this!
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
You could easily get that welded together... lol.
And to me that seems like a pretty good deal for $100. Granted you MIGHT be able to make it a little cheaper... but the ends are beaded...
themadhatter
760
Vegas
be nice if they had a port for the stock bov. So lets recap some speedsource makes the lower charge pipes(turbo to intercooler) this guy makes the upper charge pipe(throttle to fender) so when is some one going to come out with a replacement fender to intercooler pipe lol
TheRemedy
Sweeping the Streets
Nov 7, 2006
62
PA
i actually ordered this the other day...and a 2.5inch BOV pipe..im gonna lay them out and get them welded up as one peice and hopefully grind them smooth
5
one piece would be an EXTREME hassle to remove when you need to do any service...
Not to mention it has tabs to screw the extra pipes down, but no tabs to actually screw the piping itself to the engine. Too much flex would be allowed IMHO...
blackturbona
255
kirkland
one peices arnt that bad to remove, i have one and its only kinda annoying to wiggle it free while running into other things, by no means an extreme hassle
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I have a one piece, and mine is a PITA to remove. However, mine goes from the throttle body all the way through the headlight hole - the first coupler isn't until well below the headlight.
It's an even bigger PITA to get back on!
I've seriously considered getting it cut in the middle and adding another coupler.
