found a 2jz
supraGhost
212
PA
i was walking through a junkyard yesterday and i came across an sc300 with 105k miles. the 2jzge is still in it, looks pretty clean too. the actual condition on the motor is unknown, but is it worth anythign?
Its only about 300 dollars for the entire engine/ecu/ harness from the junkyard. Might be able to sell it for 4-5 since your pulling it.
You could go 2jz n/a-t and get a t4 manifold and go t4 or get a t4 to ct adapter and run a stock ct or a upgraded and get 300hp pretty easy. Use 7m electronics and all that.
