Foreverpsycotic's 91 supra turbo build.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Now that the forum is back, and I have moved onto my 2nd shell I feel it is time to post this. I picked up this shell 5.5 years ago and have been moving things over from my white 89.
Here is the 1jz/holset swapped in:
Updated with new turbo:
Artsy Shot:supra.png
Current build list for my 1991 turbo targa sport package:
Chassis and body:
Tein coilovers
S600 front bbk
evo/sti rear bbk
ST Sway Bars
Adjustable end links
Shine S2 Airguide
MKIV TT Wheels (currently an ET Street in the back, but will be changing)
Engine:
1jz
XSPower T3 manifold
Borg Warner s300sxe 63/68 turbo (.82 t3 housing)
HK$ 40mm wastegate (16psi spring)
MKIV 550cc injectors + resistor
Greddy type RS BOV
ECUMaster Standalone (including boost control)
A1000 Regulator
Aeromotive Stealth 340 pump
13v mod
MKIV AC Compressor (r134 converted)
MKIV water pump
Transmission:
R154
Spec Stage 2+ Clutch
NM V3 shifter
Interior:[/URL]
Celica GTS Steering Wheel
All new black carpet
Corbeau Seats
Future Plans:
Cams (bc264), larger injectors (probably 1000ccs), RFP1s, Spec stage 3+ disk, paint and a professional tune.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Nice!
Have you driven it with the new turbo?
Mid build I moved from CT to GA, car is still at the shop in GA. Once it gets here, it leaves (again) to go over to Evolved Tuning for a tune on the ECUMaster. Its limping along on the stock ecu right now.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
The interior is all installed now.
The downpipe had to be cut and fit, and there is a cat on the car now. The shop said it idles as quiet as stock, from what I heard on the phone that is about right.
  • Like
Reactions: supraguy@aol
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
The new wheel installed:
Harness bar test fit:
I am removing the harness bar though, I don't like the lack of security when its bolted in. I will need to have some sort of spacer made or something, it doesnt sit right with the interior plastics in.
The car goes into Evolved for a tune next week, lets see what it makes at ~16psi.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Smooth curve, shocked that it made so much torque. Going to need to eventually get that boost controller hooked up so I can ramp in boost earlier, its just a little lazy.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
That should be a lot of fun. What did you do with the Holset?
I was low 400s with the holset, but that was at 18-19psi. It spooled entirely too quickly (was seeing full boost at like 2400 rpm) and I eventually want to get some cams and rev out to around 8k.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
I like those numbers for what I'm aiming for in a daily driver, I think I'll send my Holset out to be rebuilt and run it.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Which holset do you have? I had a HX35w with the BEP .70 T3 housing. Lightning quick spool and it held 19psi to redline. Based on the fuel I was pulling, I was in the low 400s.
