Flywheel help
ZFast300Z
Trouble
Dec 15, 2007
102
Wisconsin
:1zhelp:
Would there for any reason be a shim/washer between the flywheel and the crankshaft? Or between the flywheel and the bolts that hold the flywheel on?
Im swapping flywheel onto an engine originally equipted with a flexplate for an auto and the guy I got the flywheel from gave me what appears to be a shim or washer but I cant for the life of me understand why they would use this.
shaeff
Kurt is FTMFW x2!!!!
11
Around
You don't use that shim if you're mating the motor to a manual transmission. The shim is for automatics only.
