first start up... a couple questions.
mk3-4-me
669
Milwaukee, WI
So what should i do for the first start up after my rebuild. All just rebuild stock within spec. Should i crank it first without any spark to get the oil around? Anything else that i should do?
89supra7mgte
797
colorado
pull efi fuse and crank a few times to get oil psi into system and turbo. and just double check everything to make sure its all secure then start, i prefer to let any fresh rebuild idle for about half hour or so get things seated and coolant moving. then inspect for leaks and such
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Yep. Pull the EFI Fuse and crank until you see oil pressure. You'll need a good charge on the battery and be sure to give your starter a break. Don't just crank and crank and crank and crank...
The best way to prime the turbo is to have the accordian hose off and hold the turbo fins while someone else starts it. Or they hold the fins while you start it. It only needs to be held for ~15 seconds then just simply let go.
Let idle and check for leaks.
89supra7mgte
797
colorado
+1 on the starter rest period forgot to mention that along with battery charge. Thats the last thing you need to do is burn the starter up and have to replace it after just rebuilding the engine.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
IJ.;1613509 said:
This ^
I came in to post the same thing ;)
I have this thing.
Where I hear something somewhere, and I hear it over and over. After I read it online when you said it, My grandpa said the same thing.
It can be anything, like a new word or new car. ect. haha
Zumtizzle;1613924 said:
I have this thing.
Hey I'm old but comparing me to your Grandpa come on lad!! ;)
