first attempt at a real oil cooling circuit (need approval)
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
jdub said:
120 psi for a cold start is a little on the high side don't ya think ;)
http://www.supramania.com/forums/showthread.php?t=42763
Only happens during the cold winter months JD. I believe IJ said he uses moroso filters to handle this issue as well.
I suppose I could also use a lower viscosity, but once it warms up after a few seconds it's all good! Next winter I may use a tad thinner oil....maybe.;):biglaugh: :evil2:
QWIKSTRIKE
Apr 3, 2005
1,172
IJ. said:
I have the Canton remote but Ant is correct I use the Moroso thick case filters.
I remember you telling me this when I told you about the high pressure IJ. What filter number is that IJ. I think I will just use this as a replacement filter to handle cold starts....epsecially in the winter.
QWIKSTRIKE
Apr 3, 2005
1,172
90T04 said:
I have that thermostat and it leaks. It leaked from day one. I would buy a different brand if I were to do it again.
The billet thermostat by Earls is a good unit. It's one solid piece, and is sold by summit. The cast units I found to leak, and the mocal units leaked the worst. Could have been a bad batch the guy said, but they did take them back.
Ahhh...I stand corrected. The Moroso filter looks pretty good...especially for the pressures you guys are running ;)
Edit: BTW - do you guys happen to know at what psi the by-pass opens in the Moroso filter?
Hey Ant,
Sorry didn't see this till now ;)
22470
