finished for now!!!
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
thanks to everyone who helped me with this.
car burnt to the ground after buying it. rebuilt the motor and well just about evrything else!!
shes done i might put a 2j i have in. thank you again to everyone. i hope they enjoy seeing it done.
tbcmorris
Mar 14, 2007
1,820
ij knows more about that then me. he says yes. so that means yes you have to be worried. the fire was very short and burned pretty cold. mostly everything,plastic or rubber was destroyed. even the copper wires in the harness were good. i have had no indication of any weakening. even at 6000 rpms in 5th witht the 18s everything felt as stiff as my old supra. so i am fairly sure im good. i am going take some measurements to see if anything been distorted.
tissimo
Stock is boring :(
Melbourne, FL
Clip;1200968 said:
do you have to worry about the fire weakening the frame?
If the aluminum on the engine isn't melted I dont think it got that hot to mess up the steel in the chassis.
The Hi strength Steel used in car bodies anneals around 700c (this is why you're NOT meant to use oxy welding gear as the heat affected zone is so large)
Doesn't take a huge fire to generate 700c :nono:
Personal preference I'd NEVER reuse a burnt shell but that's just me.
tbcmorris
Mar 14, 2007
1,820
Benchwarmer: thanks
Steveyblack: yep stock midnight blue
IJ: I repspect your opinon. If I see anything out of the ordinary ill just pick up another roller. I think cluless has one.
Frank: almost I was going to go to the dyno before I parked it for the winter and then drive to englishtown. But a friend of my passed that weekend so I scraped those plans. Ill go in spring. You welcome to come. Ill be dynoing at efi logics. Chris and jack from xxtuning new place and bethel.
tbcmorris
Mar 14, 2007
1,820
No but I'm moving forward on the swap slowly but surely. It would have been a matter of a coupke weeks if the built 7m sold but its still for sale. So slowly my paychecks exit my bank account and slowly the motor gets colser to being ready be to put in. I'm waiting on a ffim I'm making, a head gasket, and the turbo manifold. I can't wait wnaylonger:(. Just kidding I drove the car on my dealer plate last weekend. Maybe the last time with the 7M ;)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Hey, your not done till I say we are done, lol. Give me a call, I will help with the 2jz-ge(t) swap. No sence going NA from turbo ;-)
Thanks!
I'm NOT say bad things WILL happen just that it's NOT a chance I'd take but I'm guessing my usage will be quite different to yours (I drive fast and very hard on horrible roads)
I also manage to break a lot of indestuctable parts so won't take a chance on anything that's not 100%.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
tbcmorris;1201278 said:
I'm gonna buy jeff langes rotating assembly and a new head. So basicly the only thing lft from the leaxas 2j is block casting ;)
I would stick with a GE head though, it will be easier to use your harness, unless you want to source a jz-GTE harness and we can wire that in, using either a 1jz head or a 2jz-gte head.
