Finally swapped my 1987 taillights for 89+
Or do what I did ;)
Also, the two metal pieces under the center section, but above the trim are removable so you can pain them bodycolor like stock.
Guitarboarder28
learner
Dec 20, 2010
81
New Hampshire
www.facebook.com
Poodles;1713613 said:
Remove the silver paint on the back of the lense.
on the back of the two turn signals? i did not know that thank you! what did you use to remove it?
@1stTurbo well ya but that blacks them out lol
---------- Post added at 10:24 PM ---------- Previous post was at 10:23 PM ----------
1StTurbo;1713617 said:
VHT night shades works wonders allows you to match them
Its actually looks like shit unless you want your tails black. Better to get professionally tinted. That way you also dont get the spray can look when you look up close and there is no need for sanding and clearing.
mk3_7m
536
melbourne
I have that issue with my center lights as well. I think we both got the ADM lights. but looks isn't too much of an importance to me :p .
Are they supposed to not light up or they only light up in the 89+ shells?
Gotta pull the center section off, and there will be a nut on each one that holds it on from the back IIRC.
Dan88t
96
Binghamton, NY
Hey, what should I be aware of before I dive into this? I've had JDM 89+ tails (and all the mouldings & side markers) in my closet for about 3 years now, it's time I pull the trigger. Will it be obvious what I need to do once I pull the old tails off? I thought I'd read before that it's almost a direct replacement...
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
drill 2 tiny holes in the body for the studs on the 89+ trim and either use the 89 lock, or bend your pre-89 lock bracket with a pair of pliers..
also you should DEFINTIELY replace the taillight gaskets, either with OEM gaskets, or something similar...
aside from that, the bulb holders are plug and play, however JDM taillights don't have rear side marker wiring, but you can use 89+ USDM bulb holders if you want to keep the rear markers...
