I finished my rebuild 3 months ago after taking over 2 years to get it done. After putting 2000 miles on it i went to the dyno. We havent had a dyno in town for many years.
I only boosted 11 psi on my stock CT26. The turbo has 217,000 miles on it with no rebuilds. I will get a 57 trim upgrade soon. I will try to post the dyno chart.
The car made 248 hp to the wheels and 270 ft lb of torque. The boost was peaking 11 psi. The dyno is not a dyno jet but a dyno dynamics i believe which has a loaded drum so the numbers will be about 10 to 15% lower than a dyno jet.
The car is basically stock but for the regular items. All stock fuel system with a walbro pump. I have Ross pistons with a 9:1 compression ratio. I ported the head and the pistons and chambers have swain tech coatings. I have a spec R ebc installed. HPF 6 puck and fidenza flywheel.
Just makes you want to get the rest of the stuff and bigger turbo of course.
