Final re-assembly questions
toml
203
Adelaide, Australia
Hi all
I have a few questions now that my engine is back in the car...
- There's a coolant hose coming off of the bottom of the upper intake chamber (near the 2nd runner)... where does it go??
- There's two ring lugs coming from the wiring loom (i think :icon_conf), down towards the back of the intake manifold. I believe they are ground lugs and connect to the bolts by the 5th and 6th runners holding the intake chamber to the lower manifold?
- There's a square plug in the same group of plugs as all my transmission connectors. (A340) I don't think it was connected when I removed the engine, but I wanted to check. :)
- There's another plug coming from the wiring loom up near the 5th and 6th injector plugs. It is a brown plug with two red/black wires. I believe it was for the EGR vsv or the FPU vsv which have now been removed.
- Also wanted to make sure that the injector plugs alternate between red and silver plugs, starting with a silver one for the 1st cylinder and ending with a red for the 6th?
Let me know if you need pictures of any of these connectors/hoses/etc.
Any help appreciated, thanks.
Tom
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Tom
I think that is the starter wire. Just a thought.
toml
203
Adelaide, Australia
Hmm, I don't think so. Looks like the starter wire has two connectors - one coming from the loom and one from the battery. I have already connected these and there's still one left over!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
#1 - not entirely sure, try this diagram: http://www.cygnusx1.net/supra/library/EPC/MKIII_NATO/291420/2211_2.html - are you talking about the hose in the very bottom left corner?
#2 Correct. These are the ground wires for the ECU.
#3 - I don't recall a square plug that isn't used. Have you plugged in both the knock sensors? The starter? Reverse light indicator & speed sensor to the tranny?
#4 - sounds like the EGR plug, though I'm not certain of the wire colors off the top of my head.
#5 - the injector plugs alternate all right. I don't recall which one was first ... I had some pics stashed away, but can't seem to find them right away. If nobody else chimes in soon, I'll dig harder or look at the car.
toml
203
Adelaide, Australia
#1 - Hmm, I think it could be that hose - I'll check the bottom of the ISC valve when I get home.
#2 - Thanks :)
#3 - Starter and Both knock sensors are plugged in - I don't know which plugs are for the reverse light indicator and speed sensor to the tranny but I'll have a better look when I get home.
#4 - I'll go dig up my EGR parts out of the "old parts bucket" and check out what connector it uses.
#5 - Thanks :)
Cheers for the help GrimJack!
Tom
toml
203
Adelaide, Australia
Ok... home now.
#1 - How many hoses come out of the ISC valve? There's a fat one heading to the PCV pipe and a smaller one heading to the throttle body. Should there be another? (this one!)
EDIT: #1 - Yep, its meant to be connected to the bottom of the ISC valve. Sigh, now I have to work out how the hell i'm gonna connect it up! :p
#3 - there's two round connectors and a square one already plugged into the tranny, the spare square one is there with them. I'll try and get a picture... any ideas what it could be for?
#4 - This is indeed the FPU vsv :)
Oh, and while I was digging around at all this - it looks like there's a ring lug (like a ground/power lug) coming down towards the engine from the battery bay. It is connected to the starter motor battery cable - any ideas where that one goes? :icon_conf
EDIT: I'm thinking its the starter motor ground. I'll look up the starter motor in the TSRM/EPC and check it out...
Thanks
steve_mk3
middletown, NJ
"Oh, and while I was digging around at all this - it looks like there's a ring lug (like a ground/power lug) coming down towards the engine from the battery bay. It is connected to the starter motor battery cable - any ideas where that one goes?"
If it is the large wire that connects to the starter, it is a power cable and runs from the battery(+) to the starter. Ther is a large ground wire that runs from the (-) battery terminal, and mounts near the AC compressor bracket.
