filling in the gaps
jsnowman76
In need of another supra
Oct 17, 2006
289
Elk grove, CA
Is there anyone here that can give me a couple of pointers on filling in the holes for the antenna and the washer nozzles for the headlights.. the sprayers dont work and I would like to fill in the holes.
are there any special techniques or is it just "guess and check" kind of stuff?
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
fill in where the "spray" and antenna come out? Or remove them? If you remove the you could fiberglass and bondo...
jsnowman76
Oct 17, 2006
289
Elk grove, CA
No I've already taken them out so I just have holes in the body now. I've never done bondo or fiberglass before, so...... but thanks i'll try it and see how it turns out. I'll have to post pics because I don't think its going to be pretty.:nono:
JB91389
Jun 22, 2006
698
Ottawa
if the wholes arent too big, could you not just bondo over...like put a piece "mesh" before you bondo
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Take a ballpeen hammer and make the inside edges of the holes face downward. Then cover it with a sheet of fiberglass, then sand the fiberglass down when it's dry, then put a thin layer of bondo over it just to smooth out the body.
shaeff
Kurt is FTMFW x2!!!!
11
Around
i doubt any of the aforementioned will last very long.
i'd weld pieces of metal in, then use as little filler as you possibly can, otherwise when you slam the trunk or hood, it might just pop out.
-shaeff
shaeff
11
Around
yeah, i was mainly talking about the antenna. and the rear wiper, if one was so inclined to remove it, like me...
-shaeff
JesseH
1,153
Englewood, Ohio, United States
-shaeff
shaeffs right, the only way to ensure its going to stay there is weld it shut, thats how my rear wiper hole is sealed and I've never have to worry about it leaking again.
