Hi everyone, i have and 87 Supra N/A with a turbo motor swapped in last winter, with wiring harness and ecu. Im running a BIC 3" ddp and custom 3" exhaust. Ever since i started driving the car i can here my boost building up, it starts pulling nice as i get 3500rpm, and then my car will hit fuel cut badly anywhere from 3500 to 4000 rpm. If i dont apply the throttle as much, as to not boost as quickly, i can squeeze out a few more hundred rpm's but then its not pulling as hard as it should be. I ran it for codes maybe a month ago and if i remember correctly the codes were 32, 34, and 52.
Note: I have replaced one of the knock sensors and tried to wire it into the old wire coming off the harness. I have installed a bov, which it tee'd off into some other vaccuum lines that and autoshop rigged up. Alot of the time my bov will not chirp as im coming off the throttle if i'm not full throttle, but im thinking this could possibly be because im driving my car throughout the winter with cold temperature below -15 degrees celsius...
Any help would be appreciated!!! I just want my car to run nice and smooth and not have to worry about hitting fuel cut all the time:1zhelp:
