Few 1jzgte Fuel Questions
CrazyInside
53
Oregon
So i'm building a 1jzgte in my mk3 right now, and shooting for 500-600whp. Mods are as followed
pte 6262 twin scroll turbo
264 BC cams and cam gears
all the normal bolt ons
driftmotion honda box AeM ems.
r154
So for for fuel for that goal should I run pump gas or e85?
And if I go e85 would these http://www.jayracing.com/index.php?main_page=product_info&products_id=5944&cPath=2_305_28injectors work with drift motion top feed fuel rail, and I wouldn't need the resistor box because they are high impedance?
Would this http://www.ebay.com/itm/WALBRO-400LPH-UNIVERSAL-TANK-E85-FUEL-PUMP-W-INSTALLATION-KIT-F90000267-/290726190105#vi-contente85 pump get me my 500-600 with one? Or would I need to run 2?
And last question if I go with the e85 Do I replace all the stock fuel lines? And if so with what?
Albert
May 13, 2009
1,710
Tempe, AZ
No resistor box with the 1000cc aem will run them fine.
I'm running dual Bosch 044. Made 720hp with that setup but had 1200cc injectors.
My lines were upgraded too
CrazyInside
53
Oregon
Okay so e85 sounds like the better choice. Which lines did you upgrade to?
And when I order the injectors it has 3 options for the wiring. Says clips and pins, pig tails, or denso plug and play. Which would be best?
Albert
May 13, 2009
1,710
Tempe, AZ
I have dual 044 running dual -6 lines
The secondary inline pump has a -8 suction(pickup)
-6 return
Depending if you want to do wiring, I got pigtails and wired them in
