Fan Clutch fitment issue?
deazndude
67
Orlando
I have a JDM 2jz-gte swapped with 96+ mk4 motor mounts. The fan Clutch is from an SC300 along with the blade. When i test fitted the clutch it seems like it didn't fit, it would not slide in all the way. What's wrong? Also is one 1 inch of clearance enough? If you spaced the clutch out in your swap so you didn't have to trim the blades, please tell me how you did it or where you got the parts because I'm planning to do the same. I don't want to do a bad job and have an unbalanced fan clutch.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
what water pump is in there? it was a really tight fit if i remember right but it worked ok, dont want to use any spacers its not fun having a fan blow up in the engine bay
deazndude
67
Orlando
I couldn't tell you as I don't know, is there any way to figure out? I've heard of people spacing out their clutch I wonder how they do it.
deazndude
67
Orlando
Sorry should've been a little more clear the fan clutch isn't fitting on where it bolts up to the water pump. I think it's pushing up where the little rust line is in the water pump. Radiator is a Mishimoto.
Picture of water pump please.
That shouldn't be the issue.
Also take a picture of the fan on not fittings and the blades clearing the water neck.
The sc300 2jzge water neck is on drivers side. Gte is on passenger. 2jzge fan blades need to be trimmed to clear the water neck or else the fan will not bolt on the waterpump.
f00g00
586
Kuwait
The 2J blade will also have issues with the shroud without being trimmed. If you clean up the surface rust on the pump it might go on.
tlo86
Jul 24, 2005
3,914
Colorado
ive never had fitment issues with a 2j clutch and gte blade and oe radiator and shroud
if its just that pulley being dirty clean it, get a red scotch brite pb blaster and go to town, i use a little antiseize to keep it easy in the future.
