Exhaust questions
Turbo Habanero
4,229
Tucson,AZ
So i have a 87 Supra N/A Auto and i need exhaust, mine has a leak and i need a new CAT need it for emissions so i was wondering on prices and what all parts am i going to need.
Down pipe,CAT,mid pipe,CAT BACK is what i came up with
BrandonW
1,300
N.J.
for a n/a all you will need is another cat and the cat back exhaust 2.5 they are fairly cheap
Turbo Habanero
4,229
Tucson,AZ
you don't think that it would be better to go 3in ? and change it to 3in Down pipe with free flow cat and upgrade the headers down the road.
BrandonW
1,300
N.J.
i don't know how far you want to take the ge but 3in is a little overkill for it and is not needed, unless you are going to turbo the car later on then the cat back can be used
85celicasupra
spokane supra owner
Mar 9, 2008
256
spokane,wa
forums.celicasupra.com
if you have the money, get a header (this should come with a downpipe portion that will get it to where the stock exhaust would be)
will probably be 2.5".
Get a cat that matches size, same with a catback.
A header back 2.5" is plenty for an NA
supraman7mgte
Shut up,bitch!!
Sunny California
A N/A does not need a downpipe.Only on turbo versions only.
A 2.5 diameter exhaust would be perfect.Maybe 2.75.
Find a decent header,add a free flow cat,and then find a cat-back exaust.
Be careful of the stuff they sell on e-bay,look at shops on SM,then look on the web.
It also depends on your smog regulations where you live.
Turbo Habanero
4,229
Tucson,AZ
How much would you say this cost on AVG.
8,897
If you aren't going to build the engine up dramatically, even 2.5 inch exhaust is slight overkill. You will be louder, but not faster.
Toyota called the parts(at one time) manifold, head pipe, catalytic converter, muffler. They call the muffler and pipes "muffler". Check with the parts counter to be sure. Not that you want a Toyota exhaust.
HKS no longer produces the sport exhaust.
http://www.hksusa.com/products/?id=789
It was 60mm mandrel piping with a baffled muffler for naturally aspirateded engines. That is all the bigger you need.
Turbo Habanero
4,229
Tucson,AZ
SO......what should i go with lol. i need it to pass emssions when its on i could care less for sound i want it to sound good but i want it to beform as best as it can without spending tons of money just something decent enough
8,897
Many people here have posted about custom work at an exhaust shop for reasonable money. Have them mandrel bend 60mm or so, up to 2.5" and get a baffled muffler. Most of the aftermarket baffled mufflers will be kind of loud.
Try the FAQ at the top on upgrades for a muffler.
ValgeKotkas
2,224
Over the pond
I've read a catback from turbo supra is a bit better than 7mge stock? Though IIRC we have first bottleneck at just after the ''downpipe'' (can the catback really help then?)
Turbo Habanero
4,229
Tucson,AZ
92nsx;1312675 said:
ge = N/A = header
gte = turbo = downpipe
Correct terminology will get you a long ways ;)
this is kind of a given but what would be the correct terminology for the pipe that comes down from the headers on a N/A
Turbo Habanero
4,229
Tucson,AZ
87tomanymods;1312793 said:
if you have the money ,i would go with a header , high flow cat ,and 2.5 cat back with a straight through muffler and maby a resonator if its to loud for your taste.
I can only afford 500 so i think i am kinda short on cash right now. I was also wondering will i be able to do this my self or will i need a welder? Im really not sure how Supra's are.
