Exhaust manifold was red hot!!??
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
So I fnished putting back my GE after replacing the head gasket... The car was sitting for atleast 6 months... Anyways... so I'm driving it around the block for a few minutes... and I see a little bit of smoke coming out of the shifter area... I pull over in my house the exhaust manifold is red hot. I've never seen anything like that. So the question is: What would make my exchaust manifold glow red hot?????
te72
Classifieds Moderator
6,621
9
WHYoming
I believe the most honest answer to his question is 'heat'. ;)
But in all seriousness, timing, fuel, clogged cat, could all be reasons for this. I wouldn't drive it until it's fixed though...
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
87M-GTE;1649789 said:
Burnt valve?
Clogged CAT?
Timing is off?
I see its NA so we can rule boost out of the equation ;)
Sam
lol yeah no boost... and theres no cat.. just a testpipie.. i'm thinking it could be the timing as well..
---------- Post added at 02:47 AM ---------- Previous post was at 02:45 AM ----------
GrimJack;1649831 said:
Possibly something causing it to run lean, which boosts your EGT (Exhaust Gas Temperature) through the roof.
I thought if it ran rich thats when it would burn hotter? lean would mean not enough gas and too much air no>?
---------- Post added at 02:49 AM ---------- Previous post was at 02:47 AM ----------
whitemike;1649833 said:
What grim said is absolutely correct, I'd say one of the most common of those is TIMING. Check yours or did you just tune the distributor by ear?
lol yeah mike i kinda gotta admit I did it by ear..i guess i have to fix the timing. i never learned how to use a timing gun.
---------- Post added at 02:50 AM ---------- Previous post was at 02:49 AM ----------
yeah im not driving it now.. you said fuel.. i had the fuel sitting in the tank for a couple months... you think that would make it go bad?
---------- Post added at 02:57 AM ---------- Previous post was at 02:50 AM ----------
spikesnstuff0905;1649851 said:
Run open headers and see if it does it again, or for a less obnoxious fix try this fun little equation 0*@TDC+T1m1ng gun.
BTW, open headers would be to see if your cat is clogged.
i think your going to have to give me a break down of the mathematical equation.. i was never good at math.. fractions.. decibals.. etc. lol..
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The timing gun is really simple. Connect it to the battery, and put the pickup over the #1 spark plug wire. Make sure the notch on the front main damper is visible - I tend to use a bit of white crayon, or liquid paper. Clean off the marks on the timing gear cover that show degrees. Jumper the diag block. Start then engine. The timing light will strobe, making the notch on the front main damper appear to be stationary. Adjust the CPS until that stationary mark is sitting at the correct place on the timing gear cover.
That's all there is to it.
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
Devin LeBlanc;1650137 said:
Lean is hotter due to more air less fuel., A higher (leaner) air fuel ratio will raise EGT's
so if its running leaner as most of you guys have said... i have to adjust the timing.. with the distributer and the timing gun... I always hated the timing situation but it sounds like its very important..lol.. let's see how it goes tomorrow.. thanks guys!
