customs;1382209 said:
What do you mean there is no point..... Have you even seen the stock 1j y-pipe. It looks like someone squished it.
Bigger/cleaner diameter=better flow.
Why do you think people go with a mandrel bent exhaust over a crush bent exhaust.(providing they can afford it :icon_bigg )
I worded my response wrong and was talking about the manifolds, not the y pipe. I have seen a stock y pipe and in fact designed the ones you see cheaply knocked off on ebay and 935. I ran that one for 2 years on my car before I upgraded and sold it to the guy that sent it over seas to be knocked off.
There is no point in upgrading the manifolds with the stock turbos. Have you taken of the manifold and looked at them and compared them to the turbos and heads? There is no point upgrading the manifolds when the ports on the heads and turbines on the stock turbos are so small.
Yes upgrading the Y pipe dose make a difference and I believe makes the turbines last longer at high boost. I ran mine at 20psi for 2 years before going singe.
Its really not the cost to buy the turbo,manifold and intake. Its the cost of the injectors, going standalone, fuel pump, afm and ect. I'm fairly keen on trying to do this the right way the first time. I have had to learn the hard way one to many times when it comes to vehicles. Therefore I am now trying to go about this the right way.
It sounds like you have not learned enough doing it the hard way. Those AFM's sure are a big mod on the 1jz that uses a MAP system stock :aigo:
If you are planing to go single at some point I would spend the money on the parts that you can use later with the single not modding the stock turbo parts. But what do I know? I have only built a 7M and 3 diffrent turbo kits, 1jz with stock turbos BPU++, Single GT30R and IHI RHC7 for 550whp. Or maybe a 2jz swap stock with a DBBT67 or the built 2jz that was put in after that. Maybe it was working in a performance shop that specialized in custom turbo installs and building turbos for 2500hp drag cars. Guess I do not know much about modding Supras and cars in general.
A side note about rebuilding the stock turbos is that with the ceramic turbines chances are they will break in the rebuild process.
Good day.
