Exhaust manifold - flow
BLACKCAT
185
BHG
Does anyone have an idea of how much a stock 7mgte exhaust manifold is capable of flowing?
If ported properly what increase in airflow is possible?:naughty:
If you're serious get it extrude honed, hand porting is a total waste of time and effort as most of it can't be reached and it will only flow as much as the point of greatest restriction.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
what other options are out there for those who have a bolt on turbo where a custom downpipe and IC pipe doesnt seem seems like a lot of extra work
Actually, most of the restrictions can be reached easily (the large bumps from where the studs are in the manifold) but it's cast iron so it's shitty work to do.
500HP+ has been done on a ported stock manifold...
Doward
4,245
Alachua, FL
Poodles, Ian is saying you'd still be stuck with restrictions down the line ;) All in the center of the manifold.
As cheap as T4 manifolds are for the 7M though, I have to ask 'Why?'
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
What he said^ and you can only take down the stud humps so much, but even then you'll risk cracks.
All the prices I've seen for an extrude hone job are well in the $500 range plus.. Doesn't seem worth it when you can buy a tubular SS manifold for $200.
Yep, I agree as well, but bolt on turbos are nice when all the stock stuff bolts on...
Going full T04 isn't just the cost of the manifold...
MRSUPRA
838
Maryland
I ported my stock manifold years ago. Lots of work, not worth it. You could probably make a lot of power with the stock unported manifold, but where do you draw the line on inefficiency.
grimreaper;1305968 said:
a true bolt on mani would be nice. Same DP, same turbo, oil filter head clearance etc. like stock
All but impossible to get a better manifold in there considering how close the flange is to the head. If you move the flange, the downpipe won't work...
8,898
Based on the log manifolds for sale that claim to have supported 1000hp, more than that. As we have a semi-log, short runner. Or there are liars for vendors, big time.
8,898
I wondered if that would get your attention. Their manifold is quite "ugly", but it is not divided, so it should have a little more peak flow. I don't believe it either.
jdub
Feb 10, 2006
10,730
Valley of the Sun
If you can find one ;)
It's still a T4 flange and would require an adapter for the CT26...the downpipe length would likely need adjustment as well.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
looks like the 2jz turbonetics cast. usually run around 400$ .. . (for a knockoff) :(
