exhaust assembly question
Finnon
701
South Shields, Tyne & Wear ENGLAND
im looking at buying a second hand stainless rear section for my mkiii na. Im not too sure about 1 thing though.
with the stainless rear section being a 2.5 inch pipe approximately i wont be able to use a standard gasket when i connect it to the original front section. would exhaust assembly paste be fine to use on its own? or would it be more likely to leak?
cheers
Paul
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Have you tried test fitting it. I'm pretty sure the stock gasket will work... I suppose it depends on whether the new part's diameter is 2.5" outside diameter or inside diameter though.
Finnon
701
no, the part is located about 100 miles from where i live. my car curently has no exhaust back section. the guy who owns it sent measurements of the flange to me and they seem very similar from what i could tell.
i cant get a new stock unit over in the uk as its a discontinued part now. unless i go to toyota but itll probably be a few hundred quid. unless a company would manufacture a 1 off standard part
