eraezer - Supra MK3 -89 -Swedish Build
eraezer
851
9
Stockholm, Sweden
But it's still around the rear wheels so it's cool.
Hell no! I always want to learn more and by repairing this rust I'm learning more.
And besides this is not that much rust.
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-03-26|:-
Continued with the undercarriage and worked on it with the wirewheel.
Then I did some welding :)
Pictures:
Another friend came to visit me :)
Tried some welding inside the car
More welding under the car
Let the wireweel do it's thing
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-03-29|:-
Today I started with the hard to reach place in the right rear wheelhouse.
I took the easy way: Cutting.
Pictures:
Fitting a tin in the floor
Some cutting
Grinded down the welds and cleaned them
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-04-08|:-
THe rear right wheelhouse is soon completed, just need to connect
the outer tin with the inner tin.
Pictures:
The wheelhouse is soon complete :D
Did some welding inside the car
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-04-09|:-
No work on the supra today.
Instead I bought some stainless steelbraided hoses for the brakes and the clutch.
A local hose company did it for me and this was the first acctual part that I bought
for the supra.
Pictures:
New hoses
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-04-13|:-
The reinforcement in the wheelhouse is a little bit more complete now, just the outer tin left.
What do you think about the oil cooler? ;)
It's made for big forest working machines to cool the hydralic fluid in them.
I will only use half of it and I have to weld my own endtanks for it.
Pictures:
Did some more welding on the hard to reach place
My soon to be engine oil cooler ;)
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-04-15|:-
I have now started on the other side.
With the experience from the previous wheelhouse I hope that this one will take less time
and just go easier.
Pictures:
I started on the rear left wheelhouse
...and with that, the cutting begins
mk3design
The Name is Snakes
Jul 1, 2006
398
Arizona
Great work! Do you have a time frame on whats left of the rust removal?
Nice shop lights btw...I need more than my 2 60watt bulbs
eraezer
851
9
Stockholm, Sweden
Thank you :)
THe supra needs to be back on wheels before the end of june.
The rust that is left is in the left rear wheelhouse (rust in the same places as the right one).
Then there is a little bit of rust on the front fender and the passenger door, but these spots will have to wait.
The shop lights are a big improvment over the old ones, it's alot easier to weld and to do other types of work there.
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-04-22|:-
I spent some more time with the lathe and made 2 more bushings.
I also bought reapir kits for the rear brakes.
Pictures:
2 new bushings and repair kits for the rear brakes
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-04-28|:-
I'm welding and welding and cutting and cutting.
Pictures:
Paper templates and metall to be welded
Welded some more in the wheelhouse
I marked where to cut
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-05-02|:-
I big part of the spare wheel holder was removed to let me repair the rust that it blocks.
Pictures:
The anglecutter fell out of my hands and made some damage
The part that was removed
A little bit more that was removed
Cleaned some more around the spare wheel holder
Some new metal
Welded some more
eraezer
851
9
Stockholm, Sweden
-:|Update - 2009-05-05|:-
Today I got an IC from a friend :)
It used to be an IC for trucks, but got split into 2 pieces and this is one of them.
It's not perfect for my car, but I will see if I can get it to work.
The connections are 2.5" and 3"
If it doesnt work I will sell it to someone else.
Pictures:
My new IC
