Ive read that you can simply loosen the bolts on the subframe member to be able to get the oil pan off from under the 7m. What iwas wondering is is there enough room in there to remove and replace the oil pump? Im having weird idle pressure issues and id like to put in a new shimmed oil pump but i dont want to pull the whole engine out just for that. Thanks.
