engine harness question
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Are they all WIRED different? It's not often mentioned, but grey and green connectors almost all will plug right in regardless. The only one that I think is different is the igniter in some cases. I know I had a mismatched coil pack and I think also CPS in my old white car.
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
shit im sorry i thought this was the GTE section my info may still be good but im not sure. it may be your dizzy, and coil that require rewireing
*edit for forcedtorgues Q* they plug in but the wiring is different
the temp sensors are different. and im not sure if its the same for ge's but 89+ have different resistance values for the injectors.
primercrx
59
Lexington, South Carolina
I am using a yellow plug harness on an 89 engine just because my car is a yellow plug chassis. On my gte, I had to re wire three or four sensors, but I know two of them were on the water neck side....ge only has one on the water neck to re-wire if I remember correctly. Luckily, I had an 89 harness lying around with all the needed connectors so I could just splice the connectors I needed onto the harness.
