Engine dies after VPC hard wire
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
I recently installed an HKS vpc w/550 chips into my car but since my harness (87-88) didnt fit into my 89 supra I decided to hardwire it and used the 2.4k ohm resistor into the AFM plug and followed the newer connection chart on this thread:
http://www.supramania.com/forums/sho...t=vpc+hardwire
I removed my lexus AFM and replaced it with a pipe and installed my IAT sensor onto the ic pipe next to the 3000 pipe and installed the Map sensor onto the manifold vacuum lines. When I start the car it has a rough idle, and black smoke comes out the back and my plx systems wide band registers 14.7. After about 30 seconds the A/F richens and withing about 20 seconds it becomes richer than 11:1 and the engine dies. Last time I took it out for a drive it did not boost more than 4 psi and the engine just kept stalling. I adjusted the idle, gain, ouput, knobs but it doesnt make any difference. I really dont wanna go back to the lexus/AFM setup . Has anyone had these symptoms?
thanks
Hamed
dbsupra90
toonar
indiucky
remove the resistor and see if it makes a difference. it is only for air intake temp and will just set a code is all.
do you have another map sensor you can borrow to rule that out?
are you running an afc?
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
no I am not running and afc. I did remove the resistor it doesnt make a difference. No unfortunately I dont have another map sensor.
empera
Authorized Vendor
Philly.
if u get code 31 then that means for some reason its not getting a AFM signal. Also check ur map sensor, unplug it and see if it does the same.
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
ok I will check for this. thanks alot.
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
Ok , I get a code 24 which is the intake air temperature sensor. I have already disconnected my AFM plug, the VPC IAT is new and I tried connecting and disconnecting the MAP sensor but doesnt make a difference to engine operation. It idles fine for a while then becomes rich and then stalls. I checked my VPC to ECU wiring too. There are only 4 wires AFM, Power, Ground and rpm. They are all hardwired and correct. I dont know what else to to.
empera
Authorized Vendor
Philly.
the iat sensor might be bad. Know anyone near by that has a working vpc that u can borrow the sensors from?
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
NO but I will see if I can purchase IAT sensor from other members.
V8hntr
Undersquare
Mar 7, 2007
85
SoCal
turbogate said:
I'm not sure how much of a difference that makes, but did you double check the dip switches settings?
hi Greg:
No Actually I did not check those. I have to open the case dont I? It doesnt have any screws .
Hamed
empera
Authorized Vendor
Philly.
yea theres small tabs on the sides, just be careful and u should be able to snap the the top off.
turbogate
Life is Boost
May 18, 2005
425
South, FL
Here is how they should be set on the 89+ in case you did'nt have the diagram:
thejrman
99
omaha nebraska
thank u turbogate i have been looking for a wireing diagram now i can get my car running
but the only thing is that my wiring for my vpc dosent have a gray wire i have red white blue black brown and yellow
