Engine cutting out when gas pedal is pressed
supercharged
26
Estonia
i cant hold the gas pedal in one place-my engine shuts down-is it the throttle positioning sensor or something else:cry:
figgie
Twin Cities, Minnesot-ah
no,
first figure out of the TPS sensor is really bad.
If you have a multimeter. Should be easy to test. Otherwise you could replace it to see if it is that BUT you still need a mutlimeter to set it up :(
shaeff
Kurt is FTMFW x2!!!!
11
Around
for future reference, make a thread title that actually makes sense, otherwise you just look like an idiot. the more of an idiot you look like, the chance that someone will reply to your thread is lessened substantially.
check your codes.
and, thread title changed.
-shaeff
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
oh, another brother from the baltic's lol :D
Is she dieing when cold or when hot?
If cold, then replace your coolant temp. sensor. I had same problem when mine was dead.
If hot, then therese something wrong with fuel/air mixture.
supercharged
26
Estonia
check your codes.
-shaeff
i will try but my english isn"t very good:icon_mad:
supercharged
26
Estonia
when cold-so i will replace the coolant sens.-thanx:naughty:
